Crtical Issue - Host and Service status not coming correctly
biswajit.banerjee
Post by biswajit.banerjee »
Following issues coming Intermittently from last couple of days
1. Host status summary count not coming correctly(Zero or count mismatch between Summary dashboard and Detailed List)
2. service status summary count not coming correctly(Zero or count mismatch between Summary dashboard and Detailed List)
3. Filter result showing Zero or auto refreshing to Zero
4. Active Problem events are not getting listed.
System profile & screenshot attached.
ssax
Dreams In Code
Re: Crtical Issue - Host and Service status not coming corre
Post by ssax »
Please go to Admin > System Settings > Performance Settings > Backend Cache tab and send me a screenshot of what you have set there.
Additionally, it looks like your backendcache tmpfs is full:
tmpfs                       512M  512M     0 100% /usr/local/nagiosxi/tmp/backendcache
Please run this command:
mount -t tmpfs -o size=1g tmpfs /usr/local/nagiosxi/tmp/backendcache
Then Apply Configuration through the web interface and then attach a FRESH copy of your profile once that's completed.
Then validate to see if your issue is resolved, if it's still not resolved, try running these commands:
systemctl stop crond
systemctl stop npcd
systemctl stop nagios
systemctl stop ndo2db
pkill -9 -u nagios
for i in $(ipcs -q | grep nagios |awk '{print $2}'); do ipcrm -q $i; done
rm -rf /usr/local/nagiosxi/var/dbmaint.lock
rm -rf /usr/local/nagiosxi/var/event_handler.lock
rm -rf /usr/local/nagiosxi/scripts/reconfigure_nagios.lock
systemctl restart mysqld || systemctl restart mariadb
systemctl start ndo2db
systemctl start nagios
systemctl start npcd
systemctl start crond
systemctl restart httpd
Thank you
biswajit.banerjee
We have disabled the Backend cache and let us observe for some time .
Sure - we will keep the thread open for the time being.
