Cannot make SSL connection
alexander.ketishvili
Post by alexander.ketishvili »
Hello
I am new to nagios. Trying to find out if this product fit to our infrastructure. And the very first test fail. Please advise
/usr/local/nagios/libexec/check_http -H 10.10.10.70 -S
CRITICAL - Cannot make SSL connection
3078281496:error:14077417:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert illegal parameter:s23_clnt.c:674:
HTTP CRITICAL - Error on receive
Server receives only ssl3 connections. I think check_http plug-in tries to connect via ssl2 and ssl3 versions.
Re: Cannot make SSL connection
It seems like some HTTPS urls cause curl to fail with an "illegal parameter" error. Some claim that this error goes away if you manually specify "--sslv3". However, currently it is not possible to set a --sslv3 flag in check_http. You can check out these links for more info:
https://bugs.launchpad.net/ubuntu/+sour ... /+activity
https://bugzilla.redhat.com/show_bug.cgi?id=525496
https://bugzilla.mozilla.org/show_bug.cgi?id=526806
Sorry, I don't have a solution at this time. Try running "check_http" against a different server to see if it is going to fail.
