Performance graph seems lost some data?!
xpertech
Post by xpertech »
Some performance graph seems lost the second line data?!
ssax
Dreams In Code
Re: Performance graph seems lost some data?!
Post by ssax »
Please replace the contents of the file below:
/usr/local/nagios/share/pnp/templates.dist/default.php
With this code:
<?php
# Copyright (c) 2006-2008 Joerg Linge (http://www.pnp4nagios.org)
# Default Template used if no other template is found.
# Don`t delete this file !
# $Id: default.php 647 2009-08-08 15:02:08Z le_loup $
# Define some colors ..
define("_WARNRULE", '#FFFF00');
define("_CRITRULE", '#FF0000');
define("_AREA", '#EACC00');
define("_LINE", '#000000');
# Initial Logic ...
$counter = 200;
foreach ($DS as $i) {
        $maximum = "";
        $minimum = "";
        $critical = "";
        $warning = "";
        $vlabel = "";
        if ($WARN[$i] != "") {
                $warning = $WARN[$i];
        if ($CRIT[$i] != "") {
                $critical = $CRIT[$i];
        if ($MIN[$i] != "") {
                $lower = " --lower-limit=" . $MIN[$i];
                $minimum = $MIN[$i];
        if ($MAX[$i] != "") {
                $upper = " --upper-limit=" . $MAX[$i];
                $maximum = $MAX[$i];
        if ($UNIT[$i] == "%%") {
                $vlabel = "%";
        else {
                $vlabel = $UNIT[$i];
        $opt[$i] = '--vertical-label "' . $vlabel . '" --title "' . $hostname . ' / ' . $servicedesc . '"' . $lower;
        $def[$i] = "DEF:var1=$rrdfile:$DS[$i]:AVERAGE ";
        $def[$i] .= "AREA:var1" . _AREA . ":\"$NAME[$i] \\l\" ";
        $def[$i] .= "LINE1:var1" . _LINE . ":\"\\u\" ";
        $def[$i] .= "GPRINT:var1:LAST:\"  %3.4lf $UNIT[$i] LAST \" ";
        $def[$i] .= "GPRINT:var1:MAX:\"%3.4lf $UNIT[$i] MAX \" ";
        $def[$i] .= "GPRINT:var1:AVERAGE:\"%3.4lf $UNIT[$i] AVERAGE \\n\" ";
        if ($warning != "") {
                $def[$i] .= "HRULE:" . $warning . _WARNRULE . ':"Warning on  ' . $warning . '\n" ';
        if ($critical != "") {
                $def[$i] .= "HRULE:" . $critical . _CRITRULE . ':"Critical on ' . $critical . '\n" ';
        $comment_sum = strlen("Default Template\r"."Check Command ' ".$TEMPLATE[$i]."'\r '");
        if(($counter - $comment_sum ) > 0) {
                $counter = $counter - $comment_sum;
                $def[$i] .= 'COMMENT:"Default Template\r" ';
                $def[$i] .= 'COMMENT:"Check Command ' . $TEMPLATE[$i] . '\r" ';
Let us know the results.
