Hello
I used shipper.py to load logs form a file. Upon verifying i see the logs count is increasing but i am not able to find the logs in Logserver at all.
All i see is syslogs. Where to find my logs from a file?
application logs not showing up in Log Server
karthikv248
Re: application logs not showing up in Log Server
What is the time and timezone set to on the machine running shipper as well as the NLS machine? Is the correct date and time in the logs? Data may not appear in the NLS dashboard due to times being incorrect.
