Bulk Modifications Tool bug
AlexSavVl
Post by AlexSavVl »
Im trying to change 'notification interval' to 900 on 2882 services. Only appr 1000 services changed. If I select 20-30 services, all works fine.
Re: Bulk Modifications Tool bug
This is likely because of hitting the max vars limit in php.
You are going to need to make the following edits to the /etc/php.ini
max_input_vars=100000
then restart httpd
service httpd restart
AlexSavVl
Post by AlexSavVl »
The problem was solved. Thank you!
AlexSavVl wrote:The problem was solved. Thank you!
Great! Locking thread
