RAID controller monitoring
vy3734
Post by vy3734 »
we have a new requirement to monitor raid controller health. Does nagios provide any plugins that can do this?
i did google for third party nagios plugins to monitor raid controller, not sure which one would work for my server.
This is the raid info i found
$ lspci | grep RAID
03:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS-3 3108 [Invader] (rev 02)
I want to know if i can leverage nagios tool to monitor this RAID device.
Can anyone help?
bomahony
Re: RAID controller monitoring
Post by bomahony »
I am monitoring about 2000 raid controllers using check_lsi_raid [it requires storcli, the newer version of MegaRaidUtil] from here:
https://github.com/thomas-krenn/check_lsi_raid
As long as its not Cisco hardware. That crap is a nightmare due to there non standard logs / id codes :(
vy3734
Post by vy3734 »
hi,
thank you so much for responding back. i was able to download the plugin, install the strocli and perl dependencies.
$ lspci | grep RAID
02:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 2008 [Falcon] (rev 03)
This means that i have a RAID device on my server correct?
when i execute the following command i see
$/opt/MegaRAID/storcli/storcli64 /c0/eall/sall show all
Controller = 0
Status = Failure
Description = Controller 0 not found
i tried executing the plugin
$/usr/local/nagios/libexec/check_lsi_raid -C 1 -p /opt/MegaRAID/storcli/storcli64
Error: invalid controller number, controller not found!
Am i missing something here? This stuff is new for me. Can you please help!
looks like your Controller ID is 0 or it is saying their are no controllers found, not sure.
Try
/usr/local/nagios/libexec/check_lsi_raid -C 0 -p /opt/MegaRAID/storcli/storcli64
full disclosure we do not have this equipment in house so I cannot test it.
bomahony
Post by bomahony »
Try this to get your controller details:
bommer@XX-001 0 11:53:10 ~ $ sudo /opt/MegaRAID/storcli/storcli64 /call show
[sudo] password for bommer:
Generating detailed summary of the adapter, it may take a while to complete.
CLI Version = 007.0606.0000.0000 Mar 20, 2018
Operating system = Linux 3.10.0-693.43.1.el7.x86_64
Controller = 0
Status = Success
Description = None
Product Name = Cisco 12G SAS Modular Raid Controller
Serial Number = SK74581808
SAS Address = 570708bff885a180
Thanks for helping @bomahony
vy3734
Post by vy3734 »
@scottwilkerson
@bomhony
this is what i see after running the command
# ./check_lsi_raid -C 0 -p /opt/MegaRAID/storcli/storcli64
OK (CTR, LD, PD, CV)|CV_Temperature=24;70;85 ROC_Temperature=56;85;95 c0/e8/s0_Drive_Temperature=24;40;45 c0/e8/s1_Drive_Temperature=25;40;45 c0/e8/s2_Drive_Temperature=24;40;45 c0/e8/s3_Drive_Temperature=24;40;45 c0/e8/s4_Drive_Temperature=24;40;45 c0/e8/s5_Drive_Temperature=24;40;45
it seems to be giving out a set of temperature readings.
attached a file that has out of the command
Raid_info.txt
it seems to me that the plugin is working. I need to know if any of the disks has any issues and alert based on that.
Any inputs as to how to tweak this plugin to get the info i need?
vy3734 wrote:it seems to me that the plugin is working.
I agree.
vy3734 wrote:I need to know if any of the disks has any issues and alert based on that.
I looked over the plugin and it does check for a whole bunch of issues automatically (you just don't have any so it is reporting OK)
It looks for the following on the controller
Degraded
Offline
Critical Disks
Failed Disks
Memory Correctable Errors
Memory Uncorrectable Errors
Failed Disks
and a bunch of other items on the Physical disk, Virtual disks and the CV module. You can add -vvv to the plugin when running from the command line to see more verbose output
vy3734
Post by vy3734 »
ahh, so if any of the parameters are in critcal state it would return critical status and tell what exactly is the issue.
vy3734 wrote:ahh, so if any of the parameters are in critcal state it would return critical status and tell what exactly is the issue.
correct, at least that is what I deduced looking over the plugin code.
