Last Check Time Not Updating
talalmog
Post by talalmog »
hi,
i have nagios XI with Nagios Core 4.4.2
i see that the last update time is not changing.
i dont see errors in the DB (maybe im wrong)
nagios log looks to be running fine.
what else can be check?
what files can be check to make sure the problem is only the UI?
thanks
tal
benjaminsmith
Re: Last Check Time Not Updating
Post by benjaminsmith »
Hello @talamog,
We have a knowledgebase article on how to correct this issue.
https://support.nagios.com/kb/article.php?id=19
Likely a database issue but if the logs are good, I would check for multiple Nagios processes:
ps -ef | grep nagios.cfg | grep -v grep
Also, here's a good article to know where the log files are located within Nagios XI:
https://assets.nagios.com/downloads/nag ... ptions.pdf
talalmog
Post by talalmog »
thanks,
i sort it out by help from the URL below:
https://www.linuxincluded.com/nagios-nd ... t-running/
thank you anyway
tal
Great! Glad you got it sorted!
Locking thread
