MarcWithercy
Posts: 1 Joined: Fri Jan 25, 2019 5:05 am
Post
by MarcWithercy » Fri Jan 25, 2019 5:46 am
Hi, I am brand new to Nagios and I have installed Nagios Core on an Ubuntu 18.04 VM and enabled notifications to send via email. However, I do not receive email notifications. I installed Sendmail and can successfully send a test email to my own email. Any help/advice given would be truly appreciative.
Contents from my contacts.cfg
define contactgroup {
contactgroup_name admins
alias Nagios Administrators
members nagiosadmin
define contact {
contact_name nagios
alias nagios
host_notifications_enabled 1
service_notifications_enabled 1
host_notification_period 24x7
service_notification_period 24x7
host_notification_options d,u,r,f,s
service_notification_options w,u,c,r,f,s
host_notification_commands notify-host-by-email
service_notification_commands notify-service-by-email
email [email protected]
Contents from my commands.cfg
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "Subject: $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$\n\n***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/sbin/sendmail -v [email protected]
command_line /usr/bin/printf "%b" "Subject: $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$\n\n***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/sbin/sendmail -v [email protected]
benjaminsmith
Posts: 5324 Joined: Wed Aug 22, 2018 4:39 pm
Post
by benjaminsmith » Fri Jan 25, 2019 2:16 pm
Hello
@MarcWithercy ,
The typical Nagios Core command for notifications looks like this:
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios Monitor XI Alert *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
Notice the use of the macro
$CONTACTEMAIL$ as this will allow notifications to be sent to the email address in the contact definition.
Also, make sure you have the correct settings for notifications in your host and service definitions. For example, are notifications enabled, and if so what states are they configured to notify. Please refer to the Nagios Object definitions for more detail:
Lastly, take a look at the email log for errors:
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
Be sure to check out our
Knowledgebase for helpful articles and solutions!
