check_nt not found
tylachau
check_nt not found
Post by tylachau »
All of my check_nt checks are coming up unknown. When I go to run the command from the server itself it says check_nt is not found....
Here is what I get when I try to run the command. Directory of plugins is shown above....
nagios@nagios:/usr/local/nagios/libexec$ ls
check_apt     check_cluster  check_disk_smb  check_flexlm  check_ide_smart     check_ircd    check_mailq     check_nntp   che
check_breeze  check_dhcp     check_dns       check_ftp     check_ifoperstatus  check_jabber  check_mrtg      check_nntps  che
check_by_ssh  check_dig      check_dummy     check_http    check_ifstatus      check_load    check_mrtgtraf  check_nt     che
check_clamd   check_disk     check_file_age  check_icmp    check_imap          check_log     check_nagios    check_ntp    che
nagios@nagios:/usr/local/nagios/libexec$ check_nt -H 10.1.19.56 -p 12489 -v USEDDISKSPACE -l c
Command 'check_nt' not found, did you mean:
  command 'checkint' from deb netdiag
Try: sudo apt install <deb name>
Re: check_nt not found
When you run a check from the local directory in Linux, you should use "./"... Try:
./check_nt -H 10.1.19.56 -p 12489 -v USEDDISKSPACE -l c
