How to hide a specific service to a specific contact_groups
paolo974
Post by paolo974 »
I'm using Nagios Core 4.0.8
I would like to know how to hide a specific service to a specific contact_groups.
I would like the specific service to be hidden from Nagios Web Interface.
I have by example the 2 service definitions below:
        host_name       myhost
        service_description     service_to_be_visible
        check_command   my_check_command1
        contact_groups  admins,operators,viewers
        host_name       myhost
        service_description     service_to_be_hidden
        check_command   my_check_command2
        contact_groups  admins,viewers
So I would like "operators" to be able to see "service_to_be_visible"
but not able to see "service_to_be_hidden" for host "myhost" on the Web Interface
Thank you for your help
Re: How to hide a specific service to a specific contact_gro
How you have it setup would be correct unless the members of operators are also a member of admins,viewers OR you have added any of the contacts in operators to the cgi.cfg that allow them access to see all of the objects.
paolo974
Post by paolo974 »
Thank you for your feedback
paolo974 wrote:Thank you for your feedback
Let us know if we can be of further assistance
