Notification Variables Not Working
santosltd
Post by santosltd »
Hi Team,
We are trying to use the %notificationauthor% and %notificationcomment% but they do not appear to be working where we have placed them. I understand that the summary provides the inclusion of the both but according the the PDF I should be able to put this wherever if we have %type% as ACKNOWLEDGEMENT
Configuration of my notification messages;
services;
%type% Service Alert - %hostalias%/%service% is %servicestate%
***** Nagios XI Alert *****
%alertsummary%
Notification Type: %type%
Service: %service%
Host: %hostalias%
Address: %hostaddress%
State: %servicestate%
Info:
%serviceoutput%
Date/Time: %datetime%
Author: %notificationauthor%
NoteComment: %notificationcomment%
Respond: %responseurl%
Nagios URL: %xiserverurl%
The email coming through after acknowledging the issue;
This service problem has been acknowledged by Hani with a comment of 'Problem is acknowledged'.
Notification Type: ACKNOWLEDGEMENT
Service: Memory Usage
Host: blah
Address: blah.host.com
State: WARNING
Info:
WARNING - Memory (71%) Swap (90%)
Date/Time: 15/03/2012 10:43:46
Respond: http://someurl
Nagios URL: http://anotherurl
Could you please advise if this is a bug or if we are doing this wrong?
Hani
Re: Notification Variables Not Working
We will have to do some testing to see if this is a bug in XI or not. Meanwhile, I would suggest trying one of our new variables - %alertsummary%. It will work on 2011R2.2 and above. It will give you nice, user-friendly message, which will include the author and the commend on acknowledgements. You can set it up by going to: Configure->More Options->My Account Settings->Notification Options->Notification Messages. See the picture bellow:
Hope this helps.
santosltd
Post by santosltd »
Thanks for the response.
We are already using the alert summary which is great.
I'm just wanting to confirm with the team whether a bug exists regarding the use of the other variables.
Regards
Hani
We dug into this a bit and realized we had bad information in the documentation and changelog.
The correct macros that should be used are
%author%
%comments%
Documentation and changelog are being updated.
http://tracker.nagios.com/view.php?id=246
