Can we have a way to remove contacts from services. from the contact form.
When we want to remove contacts from services. there is no easy way to look at all the related services to a contact. Today we have to attempt to delete the contact and then it would come out with a list.
That is a crude way to manage contacts. Like the way we add contacts to services. we should be able to remove contacts from services by contact name.
Contacts related to services
Re: Contacts related to services
If you go to CCM -> Bulk Modifications Tool -> Remove Contact
You can select a contact and find relationships for the contact and then remove them in bulk on that screen
