I have created 4 host groups.
I want top 10 CPU utilization and memory utilization for those host groups .
But I know the metrics option will show the top 100 utilization.I guess in metrics option we can't customize .
I want to pull the report for particular date like Jan 1st to Jan 20 for top utilization .
Is there any way is there for this scenario ?
Nagios Reports
Re: Nagios Reports
The metrics option does allow you to configure the number of results returned but the date range isn't configurable. If the service checks are throwing alerts, perhaps you'll have better luck running a "Top Alert Producers" report under Reports > Available Reports and then using that info to dive into the performance data found under Home > Graphs > Performance Graphs.
