Next Check: showing a past date
sampaths
Post by sampaths »
We are using passive checks.
With Freshness Threshold of 420sec (7min)
Please see the attached image.
last check shows correctly but the next check is showing a past time.
Re: Next Check: showing a past date
Go to the CCM > Services, click on the "View config" next to your service, copy/paste the config to the forum. We will try to replicate this issue in-house. Thanks!
sampaths
Post by sampaths »
From the Service
# Services configuration file
# Created by: Nagios CCM 2.7.4
# Date:       2019-01-29 12:47:11
# Version:    Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
    host_name              192.168.207.58
    service_description    RFB-AccountServices_Login
    use                    RFB-AccountServices_Login
    display_name           RFB-AccountServices_Login
    register               1
# END OF FILE
From the Template it uses
    check_command                   check_dummy!3!"No results from RFB-AccountServices_Login"!!!!!!
    initial_state                   w
    max_check_attempts              1
    check_interval                  5
    retry_interval                  1
    active_checks_enabled           0
    passive_checks_enabled          1
    check_freshness                 1
    freshness_threshold             420
    flap_detection_enabled          0
    notification_interval           5
    notification_options            w,c,
    notifications_enabled           1
    contacts                        admin
    register                        0
It seems like this is a display issue only. The "next check" ("next scheduled check") is not used with passive checks as these are not initiated by nagios. When you have a passive check, in Nagios Core, you would see:
Next Scheduled Check: N/A
In XI, you should see:
Next Check: Not scheduled
however, if you had freshness enabled, you may see an actual timestamp. It would be in the past as when the freshness check is run, the "last check" timestamp is used for some reason. I believe Nagios XI should always show "Not scheduled" as far as the next check goes for passive checks. Our developers said that they would be changing this to match Nagios Core.
FYI, I don't think this (display) inconsistency would cause any issues on your system. Let us know if you have any further questions.
