Config import question
Bitflogger
Post by Bitflogger »
I'm running v5.5.8, 64-bit, VM, CentOS7.
When I go to import a configuration file, it defaults to /usr/local/nagios/etc , how do I point it to cfgprep under that directory?
I'm working off https://assets.nagios.com/downloads/nag ... ios-XI.pdf
Earl
Re: Config import question
When you go to import it should list all files under /usr/local/nagios/etc/ including the /usr/local/nagios/etc/cfgprep directory.
If it doesn't it could be a permissions issue, what are the permissions here
ls -ld /usr/local/nagios/etc/cfgprep
Bitflogger
I see it now. Please lock the case.
Bitflogger wrote:I see it now. Please lock the case.
Great! Locking
