I am now having PNP issue, though npcd is running, I am not able to see the performance graphs in the UI. I am running NagiosXIR1.7
The page title its showing is 'PNP Debugger'
The URL visited is http://xiserverip/nagios/pnp/index.php
And the output that I am seeing is....
Initalising
Using /usr/local/nagios/share/perfdata/
RRDTool /usr/bin/rrdtool found.
RRDTool /usr/bin/rrdtool is executable
PHP Function proc_open is enabled
PHP Function fpassthru is enabled
PHP Function xml_parser_create is enabled
PHP zlib Support found.
PHP GD Support found.
RRD Base Directory /usr/local/nagios/share/perfdata/ found.
Hostname xiprddb is set.
Directory /usr/local/nagios/share/perfdata/xiprddb not found.
What can be the issue, earlier I was able to see them....
pnp not showing up in UI..
Sattanathan.S
Sattanathan.S
Re: pnp not showing up in UI..
This issue is probably related to this thread:
http://support.nagios.com/forum/viewtop ... f=6&t=5035
