NagiosXI DB error
aditya.c.anand
NagiosXI DB error
Post by aditya.c.anand »
Hello Team,
We were facing db crash error , hence we repaired the database by "/usr/local/nagiosxi/scripts/repair_databases.sh"
Still we can see that the database maintenance is in "Red" state.
Kindly assist for the same.
Please find the attached profile for the same.
Re: NagiosXI DB error
you may need to remove an old dbmaint lock file
rm -f /usr/local/nagiosxi/var/dbmaint.lock
then the script should run within 5-10 minutes
