Hi Team,
I have migrated my nagios core 4.4.2 server to another machine with nagios core latest version, Is it possible to restore previous logs saved in archived on new machine, So that i can check my previous log history ? And I also want to restore pnp4nagios logs.
Regards,
rlinux57
Restore Nagios Core Logs
Re: Restore Nagios Core Logs
Yes, you can just copy them overrlinux57 wrote:Is it possible to restore previous logs saved in archived on new machine, So that i can check my previous log history ?
I'm not familiar with where these would be located on your server because there are many different ways to install pnp4nagios, but I would believe you could just move these as well.rlinux57 wrote:And I also want to restore pnp4nagios logs.
Hi Scott,
Yes, I did it and paste the nagios logs it's working. Kindly help me in order to restore pnp4nagios logs as well.
Regards,
rlinux57
Regards,
rlinux57
As I mentioned before I'm not familiar with where these would be located on your server because there are many different ways to install pnp4nagios, but I would believe you could just move these as well.
You would want to consult with the authors of pnp4nagios on this (we do not create pnp4nagios)
