I just tried to upgrade from 5.5.7 to 5.5.9 using Admin > Check for Updates > Upgrade to Latest Version
It started AOK. After handling the perl packaging, which said "Nothing to do," it said:
Stopping nagios: .done.
Starting nagios: done.
/bin/cp: cannot stat `/usr/local/nagiosxi/html/includes/dashlets/rss_dashlet': No such file or directory
The web page then said:
The update did not complete successfully. Please try updating manually.
Suggestions?
upgraded to 5.5.9 - rss_dashlet No such file or directory
[email protected]
npolovenko
- Support Tech
Re: upgraded to 5.5.9 - rss_dashlet No such file or director
Hello, @rcaperforce.com. Are you missing the RSS dashlet? Please go to the Dashboards menu in XI, then click on Manage Dashlets in the left column. Click on Browse and upload the dashlet I attached to this post.
Next, please try to manually upgrade XI from the command line:
https://assets.nagios.com/downloads/nag ... ctions.pdf
And upload the /tmp/nagiosxi/upgrade.log.
[email protected]
Thanks, npolovenko. The dashlet did the trick.
The manual "upgrade" script worked. Admin > Check for Updates shows that 5.5.9 is installed. Cheers,
-rca
-rca
[email protected]
Here is the upgrade.log file you requested. Cheers,
-rca
-rca
It seems your issue has been resolved. Is it OK if we closed this topic or you have more questions?
[email protected]
Thanks, yes it is OK to close this topic. Thanks for your help.
-rca
-rca
Great!
Locking thread
