I have installed the Nagios 4 on CentOS 7.
I am using the mailx to send the notifications.
Suddenly mail notifications are working for me.
i have attached the commands.cfg and contacts.cfg file .
Do let me know if anything else is required.
Mail Notification is not working
amitgupta19
contacts.cfg- Contacts.cfg
- (2.07 KiB) Downloaded 175 times
commands.cfg- Commands.cfg
- (7.15 KiB) Downloaded 193 times
Re: Mail Notification is not working
Do the notifications show up in the Notification Report in the Nagios GUI?
Do the notifications show up in the maillog?
Is postfix running?
tail -50 /var/log/maillogCode: Select all
systemctl status postfix-
amitgupta19
Yes Notification is showing in the GUI Console Under the Notifications.
Yes i can see in the maillog following are the logs:
Feb 1 08:34:20 cblnagios01 postfix/pickup[10997]: 62DDD408830F: uid=1005 from=<nagios>
Feb 1 08:34:20 cblnagios01 postfix/cleanup[15052]: 62DDD408830F: message-id=<[email protected]>
Feb 1 08:34:20 cblnagios01 postfix/qmgr[18247]: 62DDD408830F: from=<[email protected]>, size=820, nrcpt=1 (queue active)
Feb 1 08:34:20 cblnagios01 postfix/smtp[15054]: 62DDD408830F: to=<[email protected]>, orig_to=<nagios@localhost>, relay=172.16.5.13[172.16.5.13]:25, delay=0.09, delays=0.01/0/0.01/0.08, dsn=2.0.0, status=sent (250 2.0.0 2qaxe8tfyd-1 Message accepted for delivery)
Feb 1 08:34:20 cblnagios01 postfix/qmgr[18247]: 62DDD408830F: removed
Postfix is running on the server.
Nagios is using the email/contact as "nagiosadmin". But when i see in the Configuration-->Hosts in the Nagios Console. It shows the the contact (AmitGupta)as i have defined.
Why the mail is not getting triggered for the contact that i have defined for the hosts?
Please suggest.
Please suggest.
can you confirm that the contact AmitGupta has been set in the host/service definition?
amitgupta19
Thanks scottwilkerson .
Now i have solved the Issue.
It was due to that contact was not defined for the service.
Excellent, glad it is resolved!amitgupta19 wrote:Thanks scottwilkerson .
Locking thread
