I ran this command on Nagios server and got the timeout error. All the other resources for this remote host is getting monitored except this one.
[root@spwifi-nagios ~]# /usr/local/nagios/libexec/check_nrpe -H 192.168.210.8 -c check_logfiles -a /usr/local/nagios/cfg.d/check_car_radius_log.cfg
CHECK_NRPE: Socket timeout after 10 seconds.
CHECK_NRPE: Socket timeout after 10 seconds error
ritika.laddha
Re: CHECK_NRPE: Socket timeout after 10 seconds error
What do the logs on the remote agent (192.168.210.8) tell you? I believe by default NRPE will log to /var/log/messages
