Hi Team,
We would need your assistance to migrate NagiosXI from CENTOS to RHEL 7. Currently the server is in CENT OS has two IP addresses and we would need your assistance to migrate the same to RHEL 7.
Migrate NagiosXI from CENTOS to RHEL 7
npolovenko
- Support Tech
Re: Migrate NagiosXI from CENTOS to RHEL 7
Hello, @Pselvin. What version of CentOS are you using right now? Run:
You need to download and install the same version of XI on the RHEL 7 server and then restore from a backup taken on the old XI server:cat /etc/*release*
Thank you. Please see the version below,
CentOS release 6.10 (Final)
npolovenko
- Support Tech
@Pselvin, Ok, you can migrate using the backup and restore procedure.
Just make sure that both servers have the same version of XI installed prior to that.
You can use this KB article to install XI on the new server:
https://assets.nagios.com/downloads/nag ... -Linux.pdf
If you need to download an older version of XI, here's the link:
https://www.nagios.com/downloads/nagios ... -releases/
Thanks for your assistance. Please close this case.
