When I run >./fullinstall command on my RHEL6.1 I get the following error:
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
My install.log file looks like this:
Install error
hubert1997
Install error
Re: Install error
Is you machine registered with RedHat? Also, make sure the Optional Channel is enabled in the RedHat GUI
hubert1997
Re: Install error
I had add the Optional Channel in Redhat, i see the log is see can not find the link.
