Install Issue - Configure Firewall
nickanderson1982
Post by nickanderson1982 »
Installing Nagios Core on RHEL 7
I went to run the following commands:
firewall-cmd --zone=public --add-port=80/tcp
firewall-cmd --zone=public --add-port=80/tcp --permanent
And it said FirewallD is not running. Is there an issue if I skip over this part of the install?
Re: Install Issue - Configure Firewall
nickanderson1982 wrote:And it said FirewallD is not running. Is there an issue if I skip over this part of the install?
No problem, you can skip it if you don't run firewalld
nickanderson1982
Thanks for the quick update.
You can close the ticket, Thanks again.
nickanderson1982 wrote:Thanks for the quick update.
Locking thread
