"Apply Configuration" not more possible
today i found out that any changes to a standard check "MOUNT_Var" or "MOUNT_Data" result in config error:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/_std-linux_mount.cfg', starting on line 102)
Error: Host escalation host name is NULL
Error: Could not register host escalation (config file '/usr/local/nagios/etc/hostescalations.cfg', starting on line 16)
i tried to fix it with the config file management, no chance.
Making changes to other services are successful.
any idea?
any idea?
benjaminsmith
Re: "Apply Configuration" not more possible
Hi @scharft,
It looks like your missing the name description for your host escalation, please try to correct this, go to Configure > CCM >Alerting > Host Escalations.
When that's done, go to Configure >CCM >Tools > Config File Management and follow these steps:
1. Delete Files
2. Write Configs
3. Verify ( Are there any errors? If so correct them and repeat steps 1 and 2)
4. Restart Nagios Core
Let me know if you get it resolved.
1. Delete Files
2. Write Configs
no, i'm in a config error loop, everytime i fix the "host matching" and do the needful in the CCM, i got the same error message with a new host.
How to fix the hostgroup, host escalation.cfg i don't know, please provide steps.
Error: Could not find any host matching '369AV1001' (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 1647)
Error: Could not expand members specified in hostgroup (config file '/usr/local/nagios/etc/hostgroups.cfg', starting on line 1647)
Nagios Core 4.4.3
Last Modified: 2019-01-15
License: GPL
Reading configuration data...
Read main config file okay...
directives and data definitions. If you are upgrading from a previous
the HTML documentation regarding the config file
Nagios Core 4.4.3
License: GPL
benjaminsmith
Hi @scharft,
Can you send us your system profile so we can review your configurations.
To Send Your System Profile:
Login to the Nagios XI GUI using a web browser.
Save the profile.zip file and upload it to a cloud storage of your choice and share the link or send me the profile in a private message.
After you upload the profile please post something in this thread to bring it up in the support queue.
the profile is attached
Last edited by benjaminsmith on Mon Feb 18, 2019 11:10 am, edited 1 time in total.
Reason: profile saved
benjaminsmith
Hello @sharft,
After reviewing your configuration files, I have a few suggestions:
1. I'm not able locate 369AV1001 anywhere in your configurations files. Can you go to the Configure > CCM > Monitoring > Hosts and search for this hosts from the text box in the upper right-hand side, and remove this host and Apply Configuration. If you get any errors, please post the output.
2. It looks like you have or are importing configuration files from another system, did you have any issues with that process? If so, there is a specific order to importing configurations.
the host "369AV1001" is not in the the list => No results returned from host table.
We don't import config files from another system, this is our main system. We use a nagios worker, can this be the issue?
Are there any files in here?
ls -al /usr/local/nagios/etc/importRe: "Apply Configuration" not more possible
[root@atvinag003 scripts]# ls -al /usr/local/nagios/etc/import
total 8
drwxrwxr-x 2 apache nagios 4096 Feb 6 09:57 .
drwxrwxr-x 9 apache nagios 4096 Feb 19 14:58 ..
total 8
Can you run the following
grep 369AV1001 -R /usr/local/nagios/etc
