Report seems slow
Bitflogger
Report seems slow
Post by Bitflogger »
Hello, I'm running v5.5.8, 64-bit, VM, CentOS 7, 8 CPUs, 12GB memory, load is usually under 2.0
An availability report, for a single server, single service (checked every 5 minutes), for a 24 hour time period, took 1 minute 33 seconds to respond.
This seems slow. A BPI problem was fixed in a previous case by increasing the default memory for the PHP task, could this be the same problem?
Earl
benjaminsmith
Re: Report seems slow
Post by benjaminsmith »
Hi @Biflogger,
Can you run one of the availability report and while it is running, provide the output or a screenshot of top command for us to review? The report is generated using avail.cgi.
Reference
Maximizing Performance in Nagios XI
Bitflogger
Attached
benjaminsmith
Hi @Bitflogger,
Please PM your system profile ( go to Admin > System Profile > Download Profile)? Additionally, please run the following and PM the support.txt file as well.
ls -Rlh /usr/local/nagios/var > /tmp/support.txt
Thank you.
Bitflogger
What does PM mean?
How is system information protected from public access?
Earl
benjaminsmith
Hi @Bitflogger
Sorry about the confusion, PM means private message.
Bitflogger
OK, how to I send a PM?
Earl
benjaminsmith
Hi @Bitflogger,
On the right side of the screen, just below my name you'll see a PM icon. Click that and it will allow you to compose a direct message with attachments.
You can also click on my name as well.
Bitflogger
OK, I submitted one file. How long do I have to wait to submit the second?
Earl
benjaminsmith
Got support.txt file. Please send over the system profile.
Thanks.
