NLS Base URL
ssoliveira
NLS Base URL
Post by ssoliveira »
Good afternoon,
Which files do I need to change; to modify the standard base url of nls?
I want the application to run in /
From
http://10.144.160.28/nagioslogserver/
To
cdienger
Re: NLS Base URL
Post by cdienger »
I'm not sure it's entirely possible since some of the files may be encrypted and I wouldn't suggest doing it if is since it can lead to unintended consequences, but when you go to http://10.144.160.28/ it will load /var/www/html/index.php which redirects to http://10.144.160.28/nagioslogserver/ and Apache directs this request to /var/www/html/nagioslogserver/www/index.php. This index.php is coded to point to files in /var/www/html/nagioslogserver/ and uses relative paths to find them. Making a change like this would require replacing the intial index.php and then updating the code to find the files in the new path.
