incorrect data in performance graph
magpantayr
Post by magpantayr »
I am currently monitoring our Cisco WLC, and is using SNMP to monitor connected clients to an AP
No issues with the SNMP result but graphing seems not working properly.
My guess is because it was a Counter32 type instead of Integer. (There is a letter "c" at the end of the data)
Is there any way to fix this?
Check command:
/usr/local/nagios/libexec/check_snmp -H 192.168.233.101 -o 1.3.6.1.4.1.14179.2.2.2.1.15.244.219.230.238.182.0.1 -C calambaro -P 2c -w 25 -c 28
SNMP OK - 2 | iso.3.6.1.4.1.14179.2.2.2.1.15.244.219.230.238.182.0.1=2c;25;28;
Snmpwalk:
snmpwalk -v 2c -c calambaro 192.168.233.101 1.3.6.1.4.1.14179.2.2.2.1.15.244.219.230.238.182.0.1
SNMPv2-SMI::enterprises.14179.2.2.2.1.15.244.219.230.238.182.0.1 = Counter32: 2
Graph: (inaccurate)
Re: incorrect data in performance graph
Take a look at this forum post that talks about same issue you are having and a solution to fix it.
https://support.nagios.com/forum/viewto ... 16&t=52031
magpantayr
Thanks for the help. I was trying to search this issue on other posts but unable to find it.
Graphing is now fixed.
Cheers!
magpantayr wrote:Hello,
Cheers!
Glad it is resolved!
Locking thread
