Dear All,
For some reason, I need to generate a Capacity Planning backdate from 1 oct 2017 to 31 sep 2018.
How can I generate this capacity through NagiosXI ? Please advice. Thanks.
generate a Capacity Planning backdate from Jan 2018
Re: generate a Capacity Planning backdate from Jan 2018
I see a ticket was created and responded to regarding this. I'll lock the thread, but for anyone that may come across this:
You cannot backdate a capacity planning report, capacity planning is for calculating/predicting future values not historical values.
The closest you'll get would be the state history report so that you can view the output of the host/service check at that time. Or even the Event Log report
