Monitoring Wildfly 14 and Java 10
First, I`m sorry for my English..
I would like to monitoring my server Wildfly 14 and java 10.. The problem is the plugins are old. Can you help me?
Regards
Regards
Re: Monitoring Wildfly 14 and Java 10
You will need to monitor through JMX via this method for now:
https://assets.nagios.com/downloads/nagiosxi/docs/Monitoring-JMX-with-Nagios-XI.pdfRe: Monitoring Wildfly 14 and Java 10
Thanks for your answer. I have this error
./check_jmx -U service:jmx:rmi:///jndi/rmi://localhost:9990/jmxrmi -O java.lang:type=Memory -A HeapMemoryUsage -K used -I HeapMemoryUsage -J used -vvvv -w 4248302272 -c 5498760192
JMX CRITICAL - Failed to retrieve RMIServer stub: javax.naming.CommunicationException [Root exception is java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
java.net.SocketTimeoutException: Read timed out] connecting to java.lang:type=Memory by URL service:jmx:rmi:///jndi/rmi://localhost:9990/jmxrmijava.io.IOException: Failed to retrieve RMIServer stub: javax.naming.CommunicationException [Root exception is java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
at java.management.rmi/javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:370)
at java.management/javax.management.remote.JMXConnectorFactory.connect(JMXConnectorFactory.java:270)
at jmxquery.DefaultJMXProvider.getConnector(DefaultJMXProvider.java:17)
at jmxquery.JMXQuery.connect(JMXQuery.java:95)
at jmxquery.JMXQuery.runCommand(JMXQuery.java:70)
at jmxquery.JMXQuery.main(JMXQuery.java:116)
Caused by: javax.naming.CommunicationException [Root exception is java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
at jdk.naming.rmi/com.sun.jndi.rmi.registry.RegistryContext.lookup(RegistryContext.java:137)
at java.naming/com.sun.jndi.toolkit.url.GenericURLContext.lookup(GenericURLContext.java:207)
at java.naming/javax.naming.InitialContext.lookup(InitialContext.java:409)
at java.management.rmi/javax.management.remote.rmi.RMIConnector.findRMIServerJNDI(RMIConnector.java:1839)
at java.management.rmi/javax.management.remote.rmi.RMIConnector.findRMIServer(RMIConnector.java:1813)
at java.management.rmi/javax.management.remote.rmi.RMIConnector.connect(RMIConnector.java:302)
... 5 more
Caused by: java.rmi.ConnectIOException: error during JRMP connection establishment; nested exception is:
at java.rmi/sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:300)
at java.rmi/sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:196)
at java.rmi/sun.rmi.server.UnicastRef.newCall(UnicastRef.java:338)
at java.rmi/sun.rmi.registry.RegistryImpl_Stub.lookup(RegistryImpl_Stub.java:112)
at jdk.naming.rmi/com.sun.jndi.rmi.registry.RegistryContext.lookup(RegistryContext.java:133)
... 10 more
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/java.net.SocketInputStream.socketRead0(Native Method)
at java.base/java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:171)
at java.base/java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:252)
at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:271)
at java.base/java.io.DataInputStream.readByte(DataInputStream.java:270)
at java.rmi/sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:239)
... 14 more
In wildfly 14, jmx use "service:jmx:http-remoting-jmx", I think so..
... 5 more
... 10 more
... 14 more
You're running the plugin locally on the java server? It seems like it's having trouble connecting to service:jmx:rmi:///jndi/rmi://localhost:9990/jmxrmi, is there a way to verify that your java is running and port 9990 is accepting requests?
The 9990 port is open.
look at the imagen
Regards
look at the imagen
Regards
Is the firewall open on that port as well?
iptables -L -nRe: Monitoring Wildfly 14 and Java 10
The port is open as well.
You have ./check_jmx installed on the remote machine right? Not the Nagios server right?
Yes... I installed jmx on the remote server.
In doing some googling on this error it is possible that rmi port isn't the same as the jmx port
See answer I found here
https://serverfault.com/questions/30866 ... -jmx-error
