Hosts notifying on check 1
BanditBBS
Post by BanditBBS »
I upgraded my Dev NagiosXI to 5.5.10 and when submitting a passive host check it sends notification on check 1 of 5. Services act properly and do not notify until max check attempts has been reached.
Has this already been reported?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Hosts notifying on check 1
I haven't been able to replicate the issue on my test Nagios XI 5.5.10 box. Are you using ModGearman? What is the version of Nagios Core that you are currently using? Can you show us the host definition, along with screenshots of the State History and Notifications reports that include this host?
BanditBBS
Post by BanditBBS »
No Gearman and this was a fresh install maybe a month or 2 ago. It is not customized really at all, just use it for plugin and component dev. Core is 4.4.3.
Host Definition:
define host {
    host_name                iss-chi-nag09
    use                      xiwizard_linuxserver_host
    address                  10.160.1.21
    hostgroups               linux-servers
    max_check_attempts       5
    check_interval           5
    retry_interval           1
    check_period             xi_timeperiod_24x7
    contact_groups           admins
    notification_interval    60
    notification_period      xi_timeperiod_24x7
    _OSTYPE                  (Linux)
    _xiwizard                nrpe
    register                 1
Notification:
Host History(notice I am showing both Hard and Soft and there are no soft!):
BanditBBS
Post by BanditBBS »
I found the issue: The setting: passive_host_checks_are_soft
in other words, not a real issue!
Ah, this would do it. :) I am closing this topic.
