Hi Support,
Due to subnet settings, there are two Nagios XI on different host and check their own devices status separately.
And the client ask us to show all results on nagvis from one host.
1. What should we do to make A host (which is running Nagios XI and the main nagvis panel) can read result from B host (running another Nagios XI) and show all status on A's nagvis panel?
2. Is there only one 3306 port needed to be opened on the firewall between A host and B host? Or it needs more ports to achieve the merging?
Thanks!
Port list for merging two XI monitoring result on NAGVIS
SteveBeauchemin
Re: Port list for merging two XI monitoring result on NAGVIS
This is going to be overkill for the question you asked but I am looking into this very heavily myself.
here goes...
First you should know that NagVis can be installed stand-alone on a host.
Second you may want to use a livestatus backend. But this example is using MySQL as a backend.
The NagVis config file is
Edit the file and define multiple backends using different names.
for example - look for this in the php file - there are examples.
Find the backend area and configure or add multiple backend definitions.
The names nagiosxi-01 and nagiosxi-02 will now exist and be available for use in the NagVis GUI. You can set a master name for all maps if you prefer at a top level.
If you set this then all maps will use that backed unless otherwise specified.
Each item you add that tracks back to a Nagios XI server can have a backend set.
In a Map, click (will show the top level setting but can be changed)
In a Map, if you get into Edit mode, and right click an object and select Modify you will see on the General Tab the backend_id option again.
You can have many backends and use them in combination on any map.
There is also a livestatus method using LMD - which is a single livestatus proxy that pulls data from all your livestatus and can be used as a single item. you have many ways to succeed. https://github.com/sni/lmd I do not run LMD yet but I do plan to try it as we are growing our team and our new company is very interested in Nagios and Monitoring visualizations.
here goes...
/usr/local/nagvis/etc/nagvis.ini.phpfor example - look for this in the php file - there are examples.
; Backend definitions
; ----------------------------Code: Select all
[backend_nagiosxi-01]
; type of backend - MUST be set
backendtype="ndomy"
; hostname for NDO-db
dbhost="10.253.0.53"
; portname for NDO-db
dbport=3306
; database name for NDO-db
dbname="nagios"
; username for NDO-db
dbuser="nagios-01"
; password for NDO-db
dbpass="nagios-01"
; prefix for tables in NDO-db
dbprefix="nagios_"
[backend_nagiosxi-02]
backendtype="ndomy"
dbhost="10.254.0.53"
dbport=3306
dbname="nagios"
dbuser="nagios-02"
dbpass="nagios-02"
dbprefix="nagios_"Code: Select all
NagVis > Options > General Configuration > Object Defaults > backend = nagiosxi-01Each item you add that tracks back to a Nagios XI server can have a backend set.
In a Map, click
Edit Map > Map Options > Obj.Defaults > backend_idIn a Map, if you get into Edit mode, and right click an object and select Modify you will see on the General Tab the backend_id option again.
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
Thanks@ SteveBeauchemin for the help.
@axvers , all you would need to open port 3306 in the file to allow remote access to the server and also setup a user account in MYSQL that allows remote connections as well.
This document has an example for setting up user accounts in MYSQL for remote access.
https://assets.nagios.com/downloads/nag ... Server.pdf
Any further questions, let us know.
Hi Support,
Got it!
You save my day!
Thank you very much!!
Got it!
You save my day!
Your welcome. I'll close and lock the post for you but feel free to open a new post in the future for any other questions.
