Host Cpu usage
Rook
Host Cpu usage
Post by Rook »
Good morning,
I have an question regarding the check_nrpe_load.
On most of my ubuntu machines this works perfect, but i have an old fedora machine that is still in use, and we can't update that is giving not the correct CPU usage.
For example when the machine has a load of 1.00, the check will always come back with 0.11, 0.08, 0.05.
I'm wondering where this goes wrong, is fedora handling this different then Ubuntu?
Kind regards,
npolovenko
Re: Host Cpu usage
Post by npolovenko »
Hello, @Rook. Looks like its returning a CPU load per core. Can you post the service definition as well as the command definition from the /usr/local/nagios/etc/nrpe.cfg file from the Fedora server?
Rook
Re: Host Cpu usage
Post by Rook »
Hello npolovenko,
It seems it works now.
For centos i removed the -r in the command, then the output was correct.
Re: Host Cpu usage
Rook wrote:Hello npolovenko,
Great! glad it is resolved
Locking thread
