.xml logfile monitoring
aditya.c.anand
Post by aditya.c.anand »
Hello Team,
We are using check_log3.pl script for all log monitoring.
We have a new request to monitor a certain string like "Error while provisioning" under an .xml log file. Can we monitor .xml logs via the same plugin or is there any other plugin that can help us here?
Regards,
Aditya Anand
Re: .xml logfile monitoring
You should be able to. I added the pattern to a "test" xml file, and ran the plugin against it. During the first run, the plugin found the pattern. During the second run, the plugin showed "Found 0 lines" as there were no new lines found, matching the pattern. See below:
[root@main-nagios-xi libexec]# ./check_log3.pl -l /tmp/test.xml -p  "Error while provisioning"
WARNING: Found 1 lines (limit=1/0):   <NAGIOS_PERFDATA>Error while provisioning</NAGIOS_PERFDATA>|lines=1
OK: Found 0 lines (limit=1/0): No matches found.|lines=0
