Hi team,
NagiosXI update to latest version fails every time. kindly find the upgrade logs(below) and profile. (PFA).
kindly help us to fix it.
[root@usa0300lv6348 upgrades]# cat failed.1550588834.log
---- Starting Nagios XI Backup ----
Backing up NagiosQL...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/share/perfdata/merlin1.eng.mc.xerox.com: file changed as we read it
tar: /usr/local/nagios/share/perfdata/bluebird.opdu-dev.net: file changed as we read it
tar: /usr/local/nagios/share/perfdata/gbrwgc01uz6101.opdu-dev.net: file changed as we read it
tar: /usr/local/nagios/share/perfdata/usa0300lv6661.sdsp.mc.xerox.com: file changed as we read it
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Copying ramdisk configuration...
Backing up Nagios XI...
tar: /usr/local/nagiosxi/var/eventman.log: file changed as we read it
tar: /usr/local/nagiosxi/var/cmdsubsys.log: file changed as we read it
tar: /usr/local/nagiosxi/var/event_handler.log: file changed as we read it
tar: /usr/local/nagiosxi/var/sysstat.log: file changed as we read it
tar: /usr/local/nagiosxi/var: file changed as we read it
Backing up MRTG...
Backing up the SNMP trap interface configuration files...
cp: cannot stat ‘/etc/snmp/snmptt.conf.nxti’: No such file or directory
Backing up NRDP...
Backing up Nagvis...
Backing up MySQL databases...
Backing up cronjobs for Apache...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/autoupgrade_backup.1550588834.tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
upgrade_to_latest.sh: line 77: ./upgrade: No such file or directory
NagiosXI update to latest version fails everytime
thanigaivel.a
thanigaivel.a
Re: NagiosXI update to latest version fails everytime
Thanks now able to upgrade. however, why every time facing issue with the upgrade?
It could be because of permissions on the server, that aren't allowing the upgrade to do everything needed when running as the nagios user.thanigaivel.a wrote:Thanks now able to upgrade. however, why every time facing issue with the upgrade?
thanigaivel.a
Ok thanks, close the issue.
Locking threadthanigaivel.a wrote:Ok thanks, close the issue.
