I recently started using Nagios, I installed it on a few Windows servers so far. I don't understand what's going on with the .ini file though. After running the installation for the NS Client, it creates the .ini but it's missing much of the information. It seems to only be putting in the password and allowed hosts. I've been having to go in and copy and paste missing pieces I found from googling this issue.
Am I doing something wrong? Why am I having to manually edit the .ini file and add things like using port 12489?
NSClient .ini file issues
Re: NSClient .ini file issues
When you open the nsclient.ini file in a text editor, you would see a few commands on the top of the file. You can use them when needed. For some reason, nsclient.ini file doesn't include all of the options by default. So, in order to populate the file, you would need to navigate to the NSClient++ directory, and run the following command from the CMD prompt in Windows (as administrator):
Open the file again in a text editor to view all of the options. Make sure to review the documents below:
After modifying the file, you would need to restart the NSClient++ service, so that changes can take effect.
Hope this helps.
nscp settings --generate --add-defaults --load-allhttps://assets.nagios.com/downloads/nag ... ios-XI.pdf
Hope this helps.
OK, but is this always a manual step that needs to be done when installing the NSClient on a Windows server? I have it working, but it just seems odd that every single Windows server I install it on, I'll have to manually edit the .ini file.
And if I do have to manually edit this every install, should I consider using SNMP or WMI instead?
NSClient++ is not developed or maintained by us (Nagios), so we don't really have control over it. I often wondered why the defaults are not loaded on a new install, but I haven't found an answer to that. You can probably ask this question on the NSClient++ support forum.
https://www.nagios.org/ncpa/
You could use either one. I would recommend using NCPA though. You can read about the Nagios Cross-Platform Agent (NCPA) here:And if I do have to manually edit this every install, should I consider using SNMP or WMI instead?
