Nagios service is not running
romanshujain
Post by romanshujain »
Today i have upgraded my nagioxi from v5.4.1 to v5.5.10.
When i am checking service detail in nagiosxi it is showing "Object Does Not Exist".
While i am checking the nagios status it is showing below output(nagios is not running).
[xxxxxxxxx@xxxxx rw]$ sudo /sbin/service nagios status
[xxxxxxxxx@xxxxx rw]$ sudo /sbin/service nagios start
Starting nagios: done.
Our system is effectively down and unusable right now.
Please help ASAP.
Re: Nagios service is not running
Can you post the output of the following
tail -50 /usr/local/nagios/var/nagios.log
ps -ef|grep nagios.cfg
