I have what is likely a simple (I hope) question.
I have 10 devices that support ssh. I would like to ssh into the devices and collect various metrics. I have read about creating services and commands. Because I am an in bandwidth constrained environment I want to run all of my commands within a single ssh session. In other words, say every 30 minutes I connect to the devices and run the commands to collect the data. I'm not sure how to do this. From my reading it looks like each command will be its own ssh session. Can someone please help clarify? Thank you.
An additional wrinkle is that I cannot use the check_ssh command as these devices are read-only so I can't put an ssh public key on them for the monitoring server to permit automatic logic.
Multiple Commands in Single SSH Session
Re: Multiple Commands in Single SSH Session
The check_by_ssh plugin supports multiple -C options per session so that would be the best bet but since you're unable to use public key auth, you will likely need to install something like sshpass and then call your plugin like:
- Note: I'm using CentOS so I had to "yum install sshpass", your distro may vary
/usr/bin/sshpass -p 'YOURPASS' /usr/local/nagios/libexec/check_by_ssh -H X.X.X.X -C command1 -C command2 -C command3 -l rootCode: Select all
[root@xid ~]# /usr/local/nagios/libexec/check_by_ssh -h
check_by_ssh v2.2.1 (nagios-plugins 2.2.1)
Copyright (c) 1999 Karl DeBisschop <[email protected]>
Copyright (c) 2000-2014 Nagios Plugin Development Team
<[email protected]>
This plugin uses SSH to execute commands on a remote host
Usage:
check_by_ssh -H <host> -C <command> [-fqv] [-1|-2] [-4|-6]
[-S [lines]] [-E [lines]] [-t timeout] [-i identity]
[-l user] [-n name] [-s servicelist] [-O outputfile]
[-p port] [-o ssh-option] [-F configfile]
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.nagios-plugins.org/doc/extra-opts.html
for usage and examples.
-H, --hostname=ADDRESS
Host name, IP Address, or unix socket (must be an absolute path)
-p, --port=INTEGER
Port number (default: none)
-4, --use-ipv4
Use IPv4 connection
-6, --use-ipv6
Use IPv6 connection
-1, --proto1
tell ssh to use Protocol 1 [optional]
-2, --proto2
tell ssh to use Protocol 2 [optional]
-S, --skip-stdout[=n]
Ignore all or (if specified) first n lines on STDOUT [optional]
-E, --skip-stderr[=n]
Ignore all or (if specified) first n lines on STDERR [optional]
-f
tells ssh to fork rather than create a tty [optional]. This will always return OK if ssh is executed
-C, --command='COMMAND STRING'
command to execute on the remote machine
-l, --logname=USERNAME
SSH user name on remote host [optional]
-i, --identity=KEYFILE
identity of an authorized key [optional]
-O, --output=FILE
external command file for nagios [optional]
-s, --services=LIST
list of nagios service names, separated by ':' [optional]
-n, --name=NAME
short name of host in nagios configuration [optional]
-o, --ssh-option=OPTION
Call ssh with '-o OPTION' (may be used multiple times) [optional]
-F, --configfile
Tell ssh to use this configfile [optional]
-q, --quiet
Tell ssh to suppress warning and diagnostic messages [optional]
-w, --warning=DOUBLE
Response time to result in warning status (seconds)
-c, --critical=DOUBLE
Response time to result in critical status (seconds)
-t, --timeout=INTEGER:<timeout state>
Seconds before connection times out (default: 10)
Optional ":<timeout state>" can be a state integer (0,1,2,3) or a state STRING
-v, --verbose
Show details for command-line debugging (Nagios may truncate output)
The most common mode of use is to refer to a local identity file with
the '-i' option. In this mode, the identity pair should have a null
passphrase and the public key should be listed in the authorized_keys
file of the remote host. Usually the key will be restricted to running
only one command on the remote server. If the remote SSH server tracks
invocation arguments, the one remote program may be an agent that can
execute additional commands as proxy
To use passive mode, provide multiple '-C' options, and provide
all of -O, -s, and -n options (servicelist order must match '-C'options)
Examples:
$ check_by_ssh -H localhost -n lh -s c1:c2:c3 -C uptime -C uptime -C uptime -O /tmp/foo
$ cat /tmp/foo
[1080933700] PROCESS_SERVICE_CHECK_RESULT;flint;c1;0; up 2 days
[1080933700] PROCESS_SERVICE_CHECK_RESULT;flint;c2;0; up 2 days
[1080933700] PROCESS_SERVICE_CHECK_RESULT;flint;c3;0; up 2 days
Send email to [email protected] if you have questions regarding use
of this software. To submit patches or suggest improvements, send email to
[email protected]
I'm not aware of any plugins that will do this so something would likely need to be written, but plink from the putty package can take in username and password and execute commands via ssh. Assuming a Redhat/CentOS machine:
yum -y install putty
plink username@remotemachine -pw password "uptime;free -m"
The above would get the uptime and memory stats from the remote machine. A plugin could be written to use this command and parse the data to make it meaningful to Nagios. Some useful documents to help create custom pluggins.
https://library.nagios.com/library/prod ... s-in-perl/
https://exchange.nagios.org/directory/T ... pt/details
https://assets.nagios.com/downloads/nag ... inapi.html
http://nagios-plugins.org/doc/guidelines.html
Thank you for the response @cdienger. That's a really good suggestion. In the interim I found the check_by_ssh script and I've modified it to suit my needs. It looks like there were some mem leaks in it so I have fixed those. Looking forward to my QuickStart training later this week.
Sounds good! Are we okay to lock this up?
Yes, thank you very much for your help. RESOLVED
Glad to hear!
