No performance graphs were found for this service. If you have just started monitoring this object then it may take up to 15 minutes for the performance graphs to appear.
Verify that performance data is being returned by looking at Advanced tab of the host or status detail screen. It should look something like the highlighted part of the attached screenshot. Also check under /usr/local/nagios/share/perfdata/<hostname>/ for a rrd file with the service name. Do you see any rrd files under there?
