check_mysql_query user error
redbob365
Post by redbob365 »
i'm trying to use this plugin check_mysql_query, but I'm not lucky.
I type it in my Monitoring Server (whose IP is 172.24.3.98):
 ./check_mysql_query -H 172.24.36.71 -P 3306 -d fog -u fog -p fog -q select * from images
But I receive this kind of error:
Access denied for user 'fog'@'172.24.3.98' (using password: YES)
After that, I changed the command syntax to this:
 ./check_mysql_query -H 172.24.36.71 -P 3306 -d fog -u 'fog'@'$172.24.36.71' -p fog -q select * from images
it gives me this error:
Access denied for user 'fog'@'172.24.36.71'@'172.24.3.98' (using password: YES)
172.24.36.71 is host to be monitored.
How can I revert this error?
Re: check_mysql_query user error
Sorry we cannot provide support for Icinga
This is a Nagios forum
redbob365
Post by redbob365 »
Is there a Nagios plugin to do similar work to it?
redbob365
Post by redbob365 »
I am not referencing Icinga anymore. I can test nagios plugins just typing commands at line command, like this:
/usr/lib/nagios/plugins$ ./check_ping -H 172.24.3.1 -w 200,50% -c 1000,100% -p 5 -t 6
PING OK - Packet loss = 0%, RTA = 30.76 ms|rta=30.764000ms;200.000000;1000.000000;0.000000 pl=0%;50;100;0
I made a fresh download of Nagios Plugins 2.2.1 from this address: https://nagios-plugins.org/download/nag ... 1550770301
I found check_mysql_query within this package.
You need to create a database user that allows access from 172.24.3.98
Then you can run it like this
./check_mysql_query -H 172.24.36.71 -P 3306 -d fog -u fog -p fog -q "select * from images"
You would need to run something like this:
GRANT ALL ON *.* TO <user>@'<ip address>' IDENTIFIED BY '<password>';
To view the existing grants, you could run:
echo "show grants;" | mysql -t -uroot -p<password>
redbob365
Post by redbob365 »
Well, I did these:
1) I went to host and type this command at MYSQL:
mysql> GRANT SELECT ON *.* TO 'fog'@'%' IDENTIFIED BY 'fog';
Query OK, 0 rows affected, 1 warning (0.00 sec)
2) I came back to monitoring computer and type this command
./check_mysql_query -H 172.24.3.144 -P 3306 -d fog -u fog -p fog -q "select * from images"
It gaves me this successfully message:
QUERY OK: 'select * from images' returned 38.000000 | result=38.000000;;;
Thank you for this tip!
redbob365 wrote:Well, I did these:
Glad it is resolved!
Locking thread
