As part of our security mitigation for the shellinabox package, I removed this prior to upgrading from 5.5.8 -> 5.5.10. It removed another package called "nagiosxi-deps-el7". The yum erase worked fine. After this I was able to see the SSH web terminal was disabled [See SSH Disabled image]
I then upgraded via the web interface. This proceeded trough. It ended with the image below "Failed Upgrade". However:
- Big red box saying 'Upgrade failed'
- Multiple lines saying: 'No entry for terminal type "unknown";using dumb terminal settings.'
- Text box has 'Nagios XI Upgrade Complete!'
I rebooted the machine, then clicked back when I got back in. I see:
Your Nagios XI installation is up to date.
Latest Available Version: 5.5.10
Installed Version: 5.5.10
Last Update Check: 2019-02-26 13:24:26If I look to re-install shellinabox, nagiosxi-deps-el7 doesnt appear.
