Hi everybody,
I'm trying to set up a monitoring service for Zebra printers.
For other printer producers I haven't had any problems thanks to check_snmp_printer plugin, which returned a lot of information.
Has anyone any experience with this device?
Thank you in advance
Zebra printer monitoring
Re: Zebra printer monitoring
I'm not familiar with this printer and haven't been able to find much for documentation.
I would check with the vendor to see if they have SNMP OID's that can be monitored, then you can either check them with check_snmp, or write a plugin that can monitor them.
scottwilkerson wrote:I'm not familiar with this printer and haven't been able to find much for documentation.
Thank you, I look forward to hearing from you.
check_snmp could be enough but I have no idea about the OID and how to do
You will need to check with the vendor to see if they have SNMP OID's that can be monitored
