omd nagtrap config
skyerjoe
omd nagtrap config
Post by skyerjoe »
Hey guys
I tried to integrate the nagtrap addon from here http://nagtrap.org/doku.php/en:start in the omd distribution http://omdistro.org/
i v'e do the following install procedure:
http://nagtrap.org/doku.php/en:doku:installation
so i think sth is still wrong with the apache config ....also i'm not sure if this the right apache conf file ...
here is the modified config file:
/opt/omd/sites/testgui/etc/nagios/apache.conf:
# Apache configuration for access to Nagios web GUI
# Handle locally installed files via the internal URI /noc/check_mk/local
# These are files stored below local/share/check_mk/web/htdocs
Alias /testgui/nagios/local /omd/sites/testgui/local/share/nagios/htdocs
<Directory /omd/sites/testgui/local/share/nagios/htdocs>
Order deny,allow
allow from all
</Directory>
ScriptAlias /testgui/nagios/cgi-bin /omd/sites/testgui/lib/nagios/cgi-bin
<Directory /omd/sites/testgui/lib/nagios/cgi-bin>
Order allow,deny
Allow from all
SetEnv NAGIOS_CGI_CONFIG "/omd/sites/testgui/etc/nagios/cgi.cfg"
</Directory>
Alias /testgui/nagios /omd/sites/testgui/share/nagios/htdocs
<Directory /omd/sites/testgui/share/nagios/htdocs>
Order allow,deny
Allow from all
# Rewrite rules for handling the local-hierarchy. All URI to static
# files are redirected, if those exist in local/. Thus the user
# even can override shipped static files.
RewriteEngine on
RewriteCond "/omd/sites/testgui/local/share/nagios/htdocs/$1" "-f"
RewriteRule "(.*)" "/testgui/nagios/local/$1"
</Directory>
and here is the section which i 've added for the nagtrap config:
#### own nagtrap site####
Alias /testgui/nagios/nagtrap /omd/sites/testgui/share/nagios/nagtrap/index.html
<Directory /omd/sites/testgui/share/nagios/nagtrap>
#Options Indexes FollowSymLinks
AllowOverride All
Order allow,deny
Allow from all
</Directory>
best regards
skyerjoe
