Object file
Geo
Object file
Post by Geo »
Good morning,
is it possibile to add a new file object file (.cfg) for specific devices. For example I would like to monitor the ping service on IP cameras. Is it possible to create a camera.cfg file inside the object folder and then include it in nagios as separeted file?
Re: Object file
In the nagios.cfg if the objects directory is listed as a cfg_dir then you can simply create the file
Otherwise you can also just add the file in the nagios.cfg as something like
cfg_file=/usr/local/nagios/etc/objects/camera.cfg
Then restart nagios
