bettermap tooltip question
benhank
Post by benhank »
So i have bettermaps working and displaying properly.
The problem I am having is that no matter what entry I put in the 'tooltips" field for the panel, It is not displayed on the map:
If I click on say, the blue map point, it does not display any of the fields I've entered into the tool tips, user, username ect//)
I've even tried the fields that are auto-suggested but nothing works.
The wierd part is that I have a bettermaps panel for my asa vpn files and it is working perfectly
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: bettermap tooltip question
It looks like you have a "user" field, not sure about username.
It should show the tooltip just when you hover the blue pin, not when you click on it
benhank
Post by benhank »
I added the "user" field with the same results.
Proudly running:
Nagios Fusion
And for sure it is the message you showed is the item that has a pin at Hartford?
benhank
Post by benhank »
never mind all set. it seems that the tooltip field is case sensitive...lol changed from User to user and now it works. you can lock it up.
Proudly running:
Nagios Fusion
benhank wrote:never mind all set. it seems that the tooltip field is case sensitive...lol changed from User to user and now it works. you can lock it up.
great, Locking
