host service to remove from the list should have filter
zaji_nms
Post by zaji_nms »
Dear Expert
There is FILTER option when need to add the Host at LEFT PANE , the same way when we want to remove Host/Service , the RIGHT PANE should have FILTER option or the right side list should sorted alphabetically to catch easily.
Regards
benjaminsmith
Re: host service to remove from the list should have filter
Post by benjaminsmith »
Hi @zaji_nms,
Appreciate you input and suggestions for Nagios. I'll submit a feature request for this enhancement on your behalf. Please keep in mind that the decision to implement the enhancement is at the discretion of our development team.
Let me know if you have any questions.
