I need to enable the nrep on a windows server to check passively monitor with nagios xi.
I followed your documents, but I could not make it work,
maybe I didn't correctly configure the part of the Nagiosxi server.
Can you give me a hand?
thank you so much
walter
enable nrpe (passive) on windows with nsclient++/nagiosxi
Re: enable nrpe (passive) on windows with nsclient++/nagiosx
Was https://assets.nagios.com/downloads/nag ... Checks.pdf one of the documents? Did you configure NRDP or NSCA? In either case, check out the doc(again?) and provide the nsclient.ini file if it still isn't working.
