Hello Team,
I am facing issue on network wizard,while re scanning i can see the few interfaces but once i given the apply configuration after that i am not able to see the same interface in nagiosxi console .
I have marked in all 3 check boxes .i.e port,bandwidth, port status
Could you please help us resolve this issue ?
Network wizard issue
Re: Network wizard issue
You go through the wizard, apply the configuration, but do not see the checks under Configure > Core Config Manager > Monitoring > Services ? Is this correct?
Try the following and report any errors or warnings:
Configure > Core Config Manager > Tools > Config File Management, click:
1. Delete Files
2. Write Configs
3. Verify Files
4. Restart Nagios Core
then apply the changes as well and check to see if the services are available. If they are not, run the wizard again to try adding them.
1. Delete Files
2. Write Configs
3. Verify Files
manimurugesan
Hello ,
I have tried the below steps but still i am facing same issue.
interfaces coming while re scanning but it's not coming to the nagios console .
Could you please help me to resolve this issue ?
Please provide a screenshot of the services you are trying to add and PM me a profile(Admin > System Config > System Profile > Download Profile).
