MAX result value conflict between Graph and CLI
zaji_nms
Post by zaji_nms »
dear Expert
this is my template to plot latency graph (/usr/local/nagios/share/pnp/templates/)
$def[1] = "DEF:var1=$rrdfile:$DS[1]:AVERAGE " ;
$def[1] .= "GPRINT:var1:MIN:\"%8.0lf MIN\" " ;
$def[1] .= "GPRINT:var1:AVERAGE:\"%8.0lf AVG\" " ;
$def[1] .= "GPRINT:var1:MAX:\"%8.0lf MAX\" " ;
$def[1] .= "GPRINT:var1:LAST:\"%8.0lf LAST\\n\" " ;
Please check the attached rrd graph
MIN = 29
AVG = 33
MAX = 49
LAST = 35
and compare below CLI result.............why only MAX value is not same...........I tried many other Bandwidth and Latency graph but MAX value in CLI not matching with graph value.
rrdtool graph dummy -s20190101 -e20190201 DEF:test=$chorchor:1:AVERAGE PRINT:test:MIN:'Value - %.3lf'
Value - 29.021
rrdtool graph dummy -s20190101 -e20190201 DEF:test=$chorchor:1:AVERAGE PRINT:test:AVERAGE:'Value - %.3lf'
Value - 33.244
rrdtool graph dummy -s20190101 -e20190201 DEF:test=$chorchor:1:AVERAGE PRINT:test:MAX:'Value - %.3lf'
Value - 44.497 <<<<<<<<<<< why only this value not matching with attached rrd graph
rrdtool graph dummy -s20190101 -e20190201 DEF:test=$chorchor:1:AVERAGE PRINT:test:LAST:'Value - %.3lf'
Value - 35.000
Re: MAX result value conflict between Graph and CLI
I think how your command is defined, you are printing the MAX of the Average data.
Try this instead to get the Max value.
rrdtool graph dummy -s20190101 -e20190201 DEF:test=$chorchor:1:MAX PRINT:test:MAX:'Value - %.3lf'
zaji_nms
Post by zaji_nms »
I had tried many combinations but no luck
Value - 56.924
Can you please do trial and error in your lab environment?
I did run some tests and it seemed to match up.
Take a look at the raw data during that time to see if the numbers match up.
