Bulk add mssql database services
brucej543
Post by brucej543 »
I have a project that has an SQL database server with over 300 databases on it. The host is already defined and the mssql services. I have one of the databases defined with the mssql_database monitoring 10 services. What is the best way to bulk add the remaining databases using the same 10 mssql_database monitoring services? I have reviewed the Bulk Host Cloning and import wizard and it does not look like it would work for this project because it does look like it would address each database name.
ssax
Dreams In Code
Re: Bulk add mssql database services
Post by ssax »
You would need to copy the services and change the DB names, to speed it up you could technically do something like this:
cp /usr/local/nagios/etc/services/configname.cfg /usr/local/nagios/etc/import/newconfigname.cfg
sed -i 's/OLDHOSTNAME/NEWHOSTNAME/g' /usr/local/nagios/etc/import/newconfigname.cfg
sed -i 's/OLDDBNAME/NEWDBNAME/g' /usr/local/nagios/etc/import/newconfigname.cfg
/usr/local/nagiosxi/scripts/reconfigure_nagios.sh
brucej543
Post by brucej543 »
Thanks for your reply. I am trying to keep all the databases to be listed under the single host that these reside on. Using a new cfg file adds the services as the name of the cfg file. Can I just add the additional DB services to the existing services cfg file then import the revised cfg file? If this can be done, is there a limit to number of services to add at one time?
brucej543
Post by brucej543 »
ssax - Thanks for you info. Doing bulk services with no issues.
ssax
Dreams In Code
Post by ssax »
That's great to hear! Do you still have any outstanding questions on this or are we okay to lock this up and mark it as resolved?
brucej543
Post by brucej543 »
Thanks again and this can Locked up and marked as resolved.
